Enables or disables authentication username configuration to strip the domain name for SSH2 x509v3 publication-key authentication.
| x509v3 | Specifies x509v3 public-key authentication. |
| username | Specifies X509v3 authentication username configuration. |
| strip-domain | Specifies that when radius-password-auth and username overwrite are turned on, to strip the domain name from the username. |
| on | Specifies to enable X509v3 authentication username configuration. |
| off | Specifies to disable X509v3 authentication username configuration. (Default). |
Off.
The following example enables X509v3 authentication username configuration to strip the domain name from the username:
# configure ssh2 x509v3 username strip-domain on Note: This command is applicable only if X509v3 'radius-password-auth' and username 'overwrite' commands are turned on.
This command was first available in ExtremeXOS 32.2.
